Autorius Audi A6 C6 3,0TDI 171kw nesikuria po purkštukų keitimo
Dmitrij
Pranešimai: 20
Įstojęs: 01.01.15
Vairuoja: Audi A6 Allroad
Parašyta 2016-09-15 23:25
Sveiki. Po purkštukų keitimo nebeužsiveda. Toks jausmas, jog kurą nepaduoda. Gal galit patarti nuo ko pradėti tikrinti?
Štai ka rodo diagnostika
Thursday,15,September,2016,20:11:01:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ4F07N075436 License Plate: NAUJAS
Mileage: 289290km-179756mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 42 46 47 4F 52 53
55 56 61 62 6C 72 76 77
VIN: WAUZZZ4F07N075436 Mileage: 289290km/179756miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 402 S HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0020
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02334 785 00200
VCID: 2D5B11F4B4EFFF760F5-8078
2 Faults Found:
001653 - Cylinder 5 Glow Plug Circuit (Q14)
P0675 - 000 - Electrical Fault
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:01:17
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.25 V
Duty Cycle: 11.0 %
Temperature: 15.3°C
001654 - Cylinder 6 Glow Plug Circuit (Q15)
P0676 - 000 - Electrical Fault
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:01:17
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.25 V
Duty Cycle: 11.0 %
Temperature: 15.3°C
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 K HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0040
Revision: --H01--- Serial number: 4249036
Coding: 0000001
Shop #: WSC 02331 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Revision: 00000000 Serial number: 00000000000000
Coding: 0016776
VCID: 64CDB4D0A7A57E3E10B-8031
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100574273
Coding: 0000131
Shop #: WSC 53522 000 1048576
VCID: E3CF37CC22ABF906691-80B6
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 S HW: 4E0 035 729 A
Component: Interfacebox H43 3450
Revision: 00000000 Serial number: 351JK067530071
Coding: 0003006
Shop #: WSC 00000 000 08192
VCID: 32610288ADD1A08E527-8067
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000568383
Subsystem 3 - Serial number: 0130.10.060000000100011149˙
Subsystem 4 - Serial number: 011149˙
1 Fault Found:
00658 - Control Head
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 289219 km
Time Indication: 0
Date: 2016.09.03
Time: 16:02:09
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000318608
Coding: 0004374
VCID: 1C3DCC30DF5506FE68B-8049
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H15 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0013122
Shop #: WSC 02335 785 00200
VCID: 31630D84A8D79B962BD-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 A HW: 4E0 035 110 A
Component: MP3-Changer H44 0270
Revision: 00044000 Serial number: AUZ5ZBF3101737
Shop #: WSC 00000 000 00000
VCID: 1629DE1821795CAE5EF-8043
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 226
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:55:28
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 178
Mileage: 253251 km
Time Indication: 0
Date: 2006.05.10
Time: 12:02:25
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0HCMS.
Coding: 0013362
Shop #: WSC 02325 785 00200
VCID: 2953E5E48007E356E3D-807C
Subsystem 1 - Serial number: 6332CSME146A496DE
Subsystem 2 - Serial number: 6342CSME13261901S
Subsystem 3 - Serial number: 6352QSME17760F4BS
Subsystem 4 - Serial number: 6362QSME180344378
Subsystem 5 - Serial number: 63734SME151B1B27/
Subsystem 6 - Serial number: 63834SME152B3435-
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054063010038
Coding: 0002042
VCID: E6C92ED8D1998C2E8EF-80B3
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 932
Component: KOMBIINSTR. M73 H18 0120
Revision: 00600000 Serial number: 5HP74FJA6
Coding: 6249148
Shop #: WSC 00999 444 64523
VCID: 234FF7CCE22B3906A91-8076
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 10
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:56:49
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A158130
Coding: F551DE7F303206
VCID: ECDD5CF0CF75B67ED8B-80B9
Address 34: Level Control Labels: None
Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0060
Serial number: 00619002322600
Coding: 0000210
VCID: 2241F2C8FD31300EA27-8077
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 L
Component: MNS ECE H48 1060
Revision: 00000000 Serial number: 364JV067606407
Shop #: WSC 00859 400 87080
VCID: 3B7F2FAC7A9B61C6811-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0170
Revision: 00-00000
Coding: 0001578
Shop #: WSC 02327 785 00200
VCID: 2C5D1CF08FF5F67E18B-8079
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01022783970000
Coding: 0402161
VCID: 2E5916F8B9E9846E36F-807B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
2 Faults Found:
01519 - Bulb for Back-Up Lights; Right (M17)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 226
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:50:09
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 226
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:50:12
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000000919
Coding: 0000112
VCID: 254BE9D4EC1FC736C75-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000291528
Coding: 0001113
VCID: DEB9063809C9D4EE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0170
Revision: 00-00000
Coding: 0001578
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 785 00200
VCID: 1F47FB3CCE431DE68D9-804A
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000017
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 394J4067696771
Coding: 0000001
VCID: 2A511AE88501E84EEA7-807F
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000119467
Shop #: WSC 03214 995 56900
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2610204262
Coding: 344630393135313035442056413032363130323034323632
Shop #: WSC 00000 512 00290
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 19:58:36
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:04:46
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:04:56
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:05:22
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 289295 km
Time Indication: 0
Date: 2016.09.15
Time: 20:05:32
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0001066
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J69306E
Coding: 1020205
VCID: 1E39C638C94914EE86F-804B
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0001066
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
Component: Parkhilfe 8-Kan H12 0060
Revision: 00H12000 Serial number: 06330629602318
Coding: 0221416
VCID: 2855E0E09B0DDA5EFC3-807D
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007594093
Coding: 0010930
End
Autorius RE: Audi A6 C6 3,0TDI 171kw nesikuria po purkštukų keitimo
A90A
Pranešimai: 1197
Įstojęs: 31.12.13
Miestas: Prienai
Parašyta 2016-09-15 23:30
Purkstukus tikrino ar tik gerus dejai ?
Dmitrij
Pranešimai: 20
Įstojęs: 01.01.15
Parašyta 2016-09-15 23:32
Purkštukai nauji. Tai netikrinau.
Parašyta 2016-09-15 23:36
itariu, kad uzsiorino ;] ziurek koks reilo slegis ir bus aisku ar ateina kuras :D
Dmitrij
Pranešimai: 20
Įstojęs: 01.01.15
Parašyta 2016-09-15 23:41
Kai su VCDS tikrinau (out put test) tai kuro siurblys slėgio išvis nerodė.
Parašyta 2016-09-16 08:34
Pūstelk eterio, pažiūrėk ar griebia .
Parašyta 2016-09-16 18:51
Ne output test reik, o tiesiog ziureti rail pressure. :) Jei manualas, bandyk buksiruot. Jei automatas, tai arba pripompuok kuro, arba kaip sako su eteriu varyk. :D
Dmitrij
Pranešimai: 20
Įstojęs: 01.01.15
Parašyta 2016-09-21 21:09
Ačiu eteris padejosmileysmileysmileysmileysmileysmileysmileysmiley
streetaz23
Pranešimai: 36
Įstojęs: 24.04.15
Parašyta 2016-09-26 21:02
Ir kiek suklojai uz purkstukus?
Šiandien gimtadienius švenčia: Laimis, AUDI-90TQ, nero, kizas, djpolee, DEIVYDASSSS, Lukas1789, apsiniuhines
