Autorius Audi 80 B2 Perexodo komplektacijos
kordis
Pranešimai: 45
Įstojęs: 14.04.11
Parašyta 2011-10-15 20:42
Niekaip internete nerandu konkrečios informacijos apie Audi 80 perexodo komplektacijas. Gal kas galėtumėt padėt? Radau tik tai:
* Audi 80 (standard equipment)
* Audi 80 CC (superior equipment)
* Audi 80 CD (best equipment, 4-door only)
* Audi 80 quattro (only with quattro all-wheel drive and 66 kW)
* Audi 80 quattro CC (extended version from MY 85)
* Audi 80 SC ² (Special Edition 1986, looks like Audi 80 CD, supplied with green tinted glass, central locking, fog lights, illuminated glove box, large center console, large armrests front frame head restraints, radio "gamma", also known as quattro available, only 4-door)
* Audi 80 GTE ² (sporting equipment, with only 81 and 82kw injection engine, quattro available as well, 2 - and 4-door)
* Audi 80 GT ² (special edition, only MY 85/86, appearance and interior like Audi 80 GTE to a lack of additional instruments and small arms forward, also athletic equipment - 51kw turbo diesel or gasoline motors up to 66kw, as quattro available, only four-door counterpart. mid 86 again extended equipment with 185/60R14 tires and aluminum rims 6Jx14, green tinted glass, fog lights ...)
* Audi CS 80 (special edition only available in the Netherlands and Belgium)
Redaguotas kordis 2011-10-15 20:48
Autorius RE: Audi 80 B2 Perexodo komplektacijos
kordis
Pranešimai: 45
Įstojęs: 14.04.11
Parašyta 2011-10-16 11:33
Radau dar truputuką informacijos jei ką domins. Vertimas iš vokiečių kalbos.
Pasirodo galima turėti ir šildomas sėdynes ir cruise control'ą ir odinį originalų saloną! :D
http://translate.google.lt/translate?sl=de&tl=en&js=n&prev=_t&hl=lt&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.kaleu-koch.de%2F25410.html
Parašyta 2011-10-16 12:12
Idomios info isgaudej smiley kazkada skaiciau,tai tos cc,cd ir t.t. raides sifruojasi is vokieciu kalbos. CD tai C***** Diplomat kazkoks. tik tiek pamenu :D
1985 Audi Coupe GT
Pranešimai: 235
Įstojęs: 09.08.11
Parašyta 2011-10-16 13:33
Tikrai idomi info :) nezinojau, kad komplektacijos tokios turtingos budavo :o
Įstojęs: 11.10.10
Parašyta 2011-10-16 13:40
geriausia, kad standartinės ligos nurodytos:p
Parašyta 2011-10-16 14:38
As turiu b2 brosiuru gamykliniu kompe. Jei kam idomu-tai sakykit-pasidalinsiu smiley
kordis
Pranešimai: 45
Įstojęs: 14.04.11
Parašyta 2011-10-16 18:37
Tikrai užmesčiau akį. Gal į kokį photobucket'ą galėtum viską sumesti?
1985 Audi Coupe GT
Pranešimai: 235
Įstojęs: 09.08.11
Parašyta 2011-10-16 18:54
Jei ka turit idomaus apie b2 coupe, pasidalinkit ;)
kordis
Pranešimai: 45
Įstojęs: 14.04.11
Parašyta 2011-10-16 20:12
Skaityk tam paciam puslapy kairėj kitus straipsnius.
Redaguotas kordis 2011-10-16 21:48
1985 Audi Coupe GT
Pranešimai: 235
Įstojęs: 09.08.11
Parašyta 2011-10-17 21:39
Dekui :)
Parašyta 2011-10-17 22:28
kordis parašė:
Daug ten folderiu. Bardakas gausis,kol sukelsiu smiley PM,jei per skype reik kam nors smiley
1985 Audi Coupe GT
Pranešimai: 235
Įstojęs: 09.08.11
Parašyta 2011-10-18 12:52
Gal kas zinot is kur gaut nete visa knygute coupe b2?
kiesza
Pranešimai: 366
Įstojęs: 13.10.10
Parašyta 2011-10-19 20:02
teko tureti arba turiu ubagiu su vairo stiprintuvu, borto kompiuteriu, oro kondicionierium,automatine antena,centriniu uzraktu,kruizo kontrole,ABS,quattro pavara :) ir teko girdeti arba matyti ubagiu su odinem sedynem, elektroniniu spidometru, sildomom sedynem,elektriniais veidrodziais,el. langais, panoraminiu, skaidriu liuku, elektroniais VDO matuokliais.. ir visa tai buvo galima uzsisakyti is gamyklos
www.kvquattro.com
1985 Audi Coupe GT
Pranešimai: 235
Įstojęs: 09.08.11
Parašyta 2011-10-19 23:23
Kad nekurt bereikalingai naujos temos, paklausiu ne i tema apie oktanini skaiciu :o siandiena pasivezinau su coupe b2 5cil. 2.2 ir kazkaip mazokai traukos pasirode. Klausimas: ant dangtelio benzo parasytas tik 98E, na turejau kelis litus, tai pyliau 95E. Ar labai didele nuodeme padariau? :p is anksto dekoju uz skirta laika :D
Parašyta 2011-10-20 01:14
1985 Audi Coupe GT parašė:
Nu cia ziauriai ne i tema :D Nuodemes nepadarei. Dauguma pila i jas ir tai geriausiu atveju. Mano B2 5cyl irgi 98 prase-tik ji ir pyliau. Jis brangesnis,bet juo geriau vaziavo ir kuro sanaudos mazesnes buvo-maziau pedala spaust reikejo :)
kordis
Pranešimai: 45
Įstojęs: 14.04.11
Parašyta 2011-10-20 19:12
Nežinau pagal ką jie tuos min oktan ant dangtelio užrašinėja, bet pas mane 86m. 1.8 karbo SC su DS motoru užrašyta min oktan 98, o ant 85metų tokio pačio motoro CC min oktan 91.
Įstojęs: 11.10.10
Parašyta 2011-10-20 19:20
oktanas užrašinėjamas ir pagal tai, koks paskirstymo velenas stovi, koks vožtuvų atsidarymo laikas ir t.t. Atsižvelgiant į tai parenkama kokiu momentu koks benzino mišinys yra geriausiai suspaudžiamas ir duoda didžiausią efektą.Va tau ir painiava
1985 Audi Coupe GT
Pranešimai: 235
Įstojęs: 09.08.11
Parašyta 2011-10-22 13:35
Dekui :)
marte q
Pranešimai: 136
Įstojęs: 03.10.10
Parašyta 2011-10-30 17:04
gera informacija:)
ecka
Pranešimai: 569
Įstojęs: 21.05.09
Miestas: Trakai
Parašyta 2011-11-02 16:20
Viename forume radau gal kam bus idomu
APRAŠYMAI (Audi iki 1984 metų, t.y. ubagėms ):
C - Bazinis 1982 modelis, be jokios prabangos elementų, 1.3L 4 cilindrų variklis
CL/GLD - Pradėtas gaminti nuo 1982 metų, ėjo su 1.3L arba 1.6L 4 cilindrų varikliais
GL - Pristatytas 1982 metais, nerūdijančio plieno kėbulas, anti-shock sistema, 5 greičių pavarų dėžė, aksomo apdaila. Ėjo su 1.6L 4 cilindrų varikliu, kurio galia būdavo 75AG arba 85AG
CD/CD Diesel - Pirmieji modeliai išėjo 1982-1983 metais su 1.9L 5 cilindrų varikliu. Šie, pirmieji CD modeliai turėjo dar ir kitą pavadinimą - Audi 80 CD5S. Buvo išleista apie 31000 vienetų.
1984 metais atsirado nedidelių pakeitimų CD/CD Diesel modeliams - atsirado 2.0L 5 cilindrų varikliai, šie modeliai turėjo dar ir kitą pavadinimą - Audi 80 CD5E. Šio, patobulinto modelio variantų buvo išleista vos 6500.
Audi 80 CD/CD Diesel pati paprasčiausia komplektacija buvo veliūrinis salonas su reguliuojamais galvos atlošais, nerūdijančio plieno juostelės ant buferių, priekinių žibintų apiplovimas, 5 pavarų greičių dėžė ir lengvo lydinio ratlankiai.
GLE - Buvo gaminami 1978-1981 metais. Ėjo su 1.6L 4 cilindrų varikliu. Į standartinė komplektaciją įėjo lengvo lydinio ratlankiai. Po 1982 metais Audi 80 GLE pakeitė Audi 80 GTE.
GLS - Buvo gaminami 1978-1981 metais. Nerūdijančio plieno kėbulas, anti-shock sistema, 5 greičių pavarų dėžė, aksomo apdaila. Ėjo su 1.6L 4 cilindrų 75AG arba 85AG varikliu.
1982 metais Audi 80 GLS pakeitė Audi 80 GL.
GTE - Pristatytas 1982 metais, turėjo priekinį ir galinį spoilerius , lengvo lydinio ratlankius. Ejo su 1.8L 4 cilindrų varikliu.
L/LD - 1978-1981 modelis. Ėjo su 1.3L 4 cilindrų varikliu. 1982 metais Audi 80 L/LD pakeitė Audi 80 CL.
LC - modelio metai nežinomi, ėjo tik su standartine komplektacija, 1.3L 4 cilindru varikliu. Kėbulas - 2-ų durų.
LS - 1978-1981 modelis. Ėjo su 1.3L arba 1.6L 4 cilindrų varikliu. 1982 metais Audi 80 LS pakeitė Audi 80 CL.
Quattro - Typ81 modelis. Varomas visais 4 ratais, ėjo su 2.2L 5 cilindrų varikliu 136AG. Buvo pristatytas 1983 metais. Turėjo 5 greičių pavarų dėžę, galinį spoilerį, dvigubą išmetimo vamzdį (exhaust'ą).
1985 metais išėjo modelis su 4 cilindrų 115AG varikliu.
SC - Typ81 modelis. Tamsinti langai, juodi langų rėmai, aksomo apdaila. Audi 80 SC buvo pradėti po pirmųjų Audi 80 "facelift" modifikacijos modelių pasirodymo. Ėjo su 1.6L arba 1.8L 4 cilindrų varikliu.
Aprašymai 1984-1986 Audi (perechodams )
CC/CC TD (CC Turbo Diesel) - pradėjo gaminti 1985 metais. Jis pakeitė savo pirmataką Audi 80 CL/SC. Audi 80 CC/CC TD ėjo su 1.6L arba 1.8L 4 cilindrų varikliu.
CD/CD TD (CD Turbo Diesel) - įvestas 1985 metais. Ėjo su 4 arba 5 cilindrų varikliais, kurie taip pat buvo dedami į Audi 90. Be to, šis CD/CD TD modelis buvo prabangus, nes turėjo daug privalumų, pavyzdžiui, centrinis užraktas.
CE - Pradėjo gamint 1985m. Bazinėj komplektacijoje buvo žaliai tonuoti (tamsinti) langai, centrinis užraktas, aukštesnės kokybės radija, kupė tipo durys. Ėjo su 1.6L arba 1.8L 4 cilindrų varikliu.
CS - Modelis tiekiamas tik Nyderlanduose, nuo 1985 metų. Bazinė komplektacija: priekinis spoileris, žaliai tonuoti (tamsinti) langai, rūko žibintai, centrinis užraktas ir odinis vairas. Ėjo su 1.6L arba 1.8L 4 cilindrų varikliu.
GT/GTD - Pradėtas gaminti 1985 metais. Sportiška ir tuo pačiu prabangi versija. Bazinė komplektacija galėjo pasigirti galiniu spoileriu, atviromis galvos atramomis, juodais langų rėmais, sportinėmis sėdynėmis ir specialia, smūgius "sugeriančia" sistema.
GTE - 1985 metais pradėtas gaminti modelis, kuris pakeitė savo pirmtaką. Pasižymėjo priekiniu ir galiniu spoileriais, lengvo lydinio ratlankiais. Ėjo su 1.8L 4 cilindrų varikliu.
Quattro - Typ81 modelis. Varoma 4 ratais, ėjo su 2.2L 5 cilindrų 136AG varikliu. 1985 metais atsirado modelis su 4 cilindrų 115AG varikliu.
Redaguotas ecka 2011-11-02 16:22
